Use this procedure to configure the Link Layer Discovery Protocol (LLDP) vendor-specific information on a call server or a file server.
After you configure LLDP vendor specific call server information, the SIP Proxy of the phone is configured as transport type Transport Layer Security (TLS) port 5061. This option is available depending on the operating system of the call server.
Configure the LLDP vendor-specific information on a call server:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#lldp vendor-specific call-server 1 192.0.2.0
The following table defines parameters for the lldp vendor-specific command.
Variable |
Value |
call-server <1-8> <A.B.C.D> |
Specifies the Link Layer Discovery Protocol (LLDP) vendor specific information on the call server number and the IP address. |
file-server <1-4> <A.B.C.D> |
Specifies an LLDP vendor specific information on the file server number and the IP address. |
